Hello, I have a ICX6610 configured with SSH. Everything works fine since last week. Unable to connect with our account via Tacacs+ server. Only the local account works. All my others switches are OK and works fine. So it's not the tacacs server. And if I look into the logs of tacacs server, i did'nt see the request. It's like as if the resquest is not send to the server.
SSH is configured like that:
aaa authentication login default tacacs+ local
tacacs-server host xx.xx.xx.xx
crypto key gen rsa
I zeroize the crypto key, same problem. I remove aaa authentication and put it back, same problem. I reboot, same problem. Remove and put back tacacs-server address, same problem.
Any idea?
Thank you
