I have an ICX 1750 c12P that seems to be brain dead?
The syst LED is amber, is that normal? I thought it should be green?
None of the status LEDs are on, pressing the status button nothing happens.
I tried to do a factory reset per the manual, (hold reset button down while applying power), all the LEDS blinked amber but nothing happens after that.
Is it a boat anchor now?
