Hi guys!
I have a partner configuring 7150-C08P (running 8.0.91t) connect to 7150-24P (.90d). It works if using RJ45 ports to connect. When using SFP 1G, the C08P end is up, -24P end is down (same result with all port). They use a 7150-12P to test with 7150-24P and everything is fine. Any suggestion for the problem with -C08P and -24P using 1G SFP link?
Thanks & Best regards,
