ICX Switches
Questions on PIM MCACHE names and values
Running into a hit and miss situation, and looking at some of the current values associated with mcache. I haven't found anything as to what terms "mcache SLIB Sync" and "mcache" represent when I issue the command show ip pim resource. Are these related to the system default values? Or something separate?
Here is the output:
alloc in-use avail get-fail limit get-mem size init
mcache SLIB Sync 560 309 251 0 64960 10100960 34 280
mcache 896 309 587 0 12992 4321220 1529 56
I'm concerned that when the allocation is used up that our video streams begin to take a hit.
Hardware is ICX 7750
Firmware is SWR08030h
hashim_bharooc1
Hi Todd,
Hope you are doing great.
PIM
employs a number of memory pools and some have limits as to how large they can
grow. In the event that the upper limit is reached, further allocations shall
fail.
As long as you do see get-fail as 0 and we have resources available then it should not make a difference as we still have hardware records available for this field.
Your problem lies somewhere else.
Best to open a case with TAC and further debug this issue.
Hope this helps
Hashim
