My Ruckus ICX-7150-C12P keeps power cycling and causing my APs to reset. I've tried har-powering off the Switch and resetting. Neither has worked. I am connected directly to my modem now.
I am having the same issue. It started on July 31st.
To all I mine was the same thing and a few post helped.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/ICX-7150-Switch-Rebooting-Constantly/m-p/72446
my biggest barrier that took awhile to solve was having to use a Mac to CLI into the switch once I got the right drivers installed etc it was pretty easy to follow the above directions.
This one for the booting issue going to the secondary.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-RUCKUS-ICX-7150-C12P-Switch-using-a-USB-flash/td-p/46781
this one to fix it so it would not happen again.
Update: I did not take any of the steps in the links above at this point yet. However, the Switch seems to be working correctly and not powering off. Did the issue correct itself? Should I still go ahead and perform the firmware upgrade in the links above?
I would as its like a ticking time bomb.
Hi @eldmattd
Thank you for the information provided. Let me share a final step.
1. Gain Console access; please refer to the next guide:
/kb/articles/8-how-to-access-the-command-line-interface-cli-of-the-ruckus-icx-7150-c12p-switch
2. Once you have access, please gather the following outputs:
show version
show flash
show chassis
show log
3. Factory reset the Switch from CLI
erase system factory-default
4. If the issue persists, pleased share the logs of the failure
Best regards,Yarenis HernándezRUCKUS | Lennar Home Community Support
Hi @J_L
Hope you are doing well
As this case is raised by @ eldmattd
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly. Please raise a new post with the above description on RUCKUS Lennar Support
Thank you again for your understanding.
If the unit is running a version under 08095g, please upgrade to avoid the issue. Please refer to the next Guide:
/kb/articles/1-how-to-upgrade-ruckus-icx-7150-c12p-from-non-unified-forwarding-image-ufi-to-a-stable-ufi-version
Please see the Important Announcement Below.
Important Announcement! As a part of our Community Platform Migration the community will be temporarily placed into read-only mode from Monday, August 10 through Monday, August 17 (and only during this time period), For any Lennar RUCKUS devices related issues please email us at ruckus-lennar-support@ruckusnetworks.com for assistance. You can also continue reviewing the Lennar Knowledge Base and the Lennar Support board during this period.
Thank you!
Thank you.
Best regards, Yarenis Hernández RUCKUS | Lennar Home Community Support
