The switch, ICX 7150-C12P, will no longer boot. When plugged in all lights on the front will flash yellow once, then no other feedback is given. Issue persists when using alternate cables and outlet as well.I’ve also tried holding the reset button while plugging it in, issue persists.Switch was acquired with the home via Lennar. I am the original owner of the home.Video Showing Working Outlet + Light Flash
https://www.dropbox.com/scl/fi/7ntur7b1uyce1d7qpjnh6/Video-Jul-12-2026-16-55-40.mov?rlkey=rxf3h79muv5zqsv4prv0jfuwg&st=y6sfr1al&dl=0
Hello @Jay2003 Greetings!
We appreciate the information you provided regarding your RUCKUS ICX-7150-C12P Switch.Please try performing the software recovery. If the issue persists, please let me know so that we can proceed with an RMA.How to perform a Software recovery on an ICX7150 switchhttps://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Kind regards,Sofia Gätjens
Technical Support Engineer L2 TAC Wired | RUCKUS Networks
Ruckus Networks is now part of Belden Inc.
Hello @Jay2003
Based on the troubleshooting performed, your ICX-7150-C12P Switch is not responding properly, and the Software Recovery process has been unsuccessful. A hard reset was also attempted; however, the issue still persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, Please use the private chat option to respond so we can proceed further. For your reference, I have included a screenshot below.
Thank you again for your patience and understanding. Best regards,RUCKUS | Lennar Home Community Support
Thank you I replied to the message pictured below:
@Jay2003 Hi
I’ve raised an RMA case and sent you a private message with the RMA details. You will receive further notifications from the RMA case.
Please check and let me know if you have any questions.
Thank you once again for your patience.
