Hello @MrG6872
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
1. Was there any power outage before you started facing this issue?
3. May I know how many Access Points are connected to the Switch?
Hello @MrG6872 ,
This is a follow-up in reference to the case you have opened in the RUCKUS Lennar Support Community.
We may need to check some configurations of your RUCKUS ICX-7150-C12P Switch to troubleshoot this issue.
To proceed with troubleshooting the issue, please follow the steps outlined below to access the Command Line Interface (CLI) and provide the necessary command outputs:
1. First, identify the current IP address assigned to the switch ICX-7150-C12P by your local router. You can use an IP scanner tool to easily locate the switch's IP address on your network. Here is a guide on how to perform this using IP Scanner free applications:
2. Once you have identified the IP address of the switch, proceed to access the Command Line Interface (CLI) of the RUCKUS ICX-7150-C12P switch. Here is a guide on how to access the CLI:
If you can access the Command line the prompt should look like below:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
3. After successfully accessing the CLI, please execute the following commands and provide the outputs:
show version
show flash
show inline power
show inline power detail
show interface brief
show lldp neighbors detail
Please share the command outputs or screenshots if you encounter any issues or errors during these steps.
Hi @MrG6872 ,
Thank you.
Best regards,Pinky Rajendran
Hi @MrG6872
This is Imran, one of the RUCKUS Tech Support Senior Engineers.
