Hey!
I believe I have corrected the issue with my iPhone and "Termius" App that I downloaded. I haven't fully tested to see if everything is working properly but at least things are loading on my phone and music is playing through my Alexia (which it wasn't doing either before)
As you can see below, the "Running Image" is now referencing "SPS" but the version 08.0.90d... Should I still change this version to 08.0.90e as referenced above or leave as is?
Appreciate all your help!! I'm not sure why Ruckus is not allowed to discuss solutions with Lennar Homeowners for their products.. It makes it extremely difficult to get issues resolved. I hope that changes because that average person will not be able to fix their equipment themselves, even with a step-by-step detail that you have provided. Service (most times) is better that the product itself. If a company/brand doesn't provide the necessary support, then next step is substituting their product for on-demand service.
Again, I appreciate your help!
Hi @ANG1883 ,
As per the case description, I understand that your RUCKUS setup is not working after the power outage.
2. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Hi. I do not have a "Camera or Inset Photo" on the top bar. Next to the "Insert Emoji" I have a "Table" button. Lets proceed without he screenshots.
Answers to above questions:
1) On my "Switch" in your first photo.
On the LEFT SIDE under "STATUS" --> The "STAT" light is GREEN.
In the Middle --> The "SYST", "UPDATE", "PWR" lights are GREEN.
On the RIGHT SIDE --> I have an ORANGE Cable & 2 BLUE Ethernet Cables connected and they are ALL GREEN. (Orange has always been connected to my AT&T Internet Source... ant that is Functioning correctly and GREEN)
2) I have two R510 AP's.
First is on the First/Main Floor. This one has 4 GREEN lights on. (PWR, CTRL, 2.4g, & 5g) ALL GREEN.
Second is on the 2nd Floor. This one currently has 3 GREEN lights on. (PWR, 2.4g, & 5g) are GREEN, but the CTRL light is OFF.
What I tried to do:
I Restarted all devices. (Same issue/No FIX)
I Pressed the "RESET" button on the AP that the "CTL" lights is OFF. (Same Issue/No Fix)
I Moved Ethernet Cables to different ports on "SWITCH". (Same Issue/No Fix)
Hello @ANG1883
From the response shared, I understand that you have 2 Access points and one of which are having all lights turned on and green including CTL and the other AP having all lights except CTL turned Green.
If there are multiple APs, only one among those APs will act as a master AP and that master AP will have their CTL turned on and green. The CTL on all other APs will be off.
Also, I understand that you are facing internet issues after the power outage.
We need to check few configurations on the Switch to assist you further.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
/kb/articles/10-how-to-find-the-ip-address-of-the-ruckus-devices-switch-and-aps-using-ip-scanner-free-applications
/kb/articles/8-how-to-access-the-command-line-interface-cli-of-the-ruckus-icx-7150-c12p-switch
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
Unfortunately am unable to download anything because I'm working off my "Work Computer" which needs admin rights to install any downloads...
I did Identify my IP Address and put it in the search bar. I have logged in utilizing the default User Name and Password from Lennar.
All I see here is my Router Options.
Example: "Monitor", "Stack", "Port", "IP", "System", "Management", "RIP", Command"... Etc.
Is there anything I could do here to test system?
