All,
Have a r750 was not able to get into gui via 192.168.0.1 so I factory defaulted the unit.
Now the unit power led just flashes on power up....
any ideas?
Hi @sfdoc5 Greetings!!!
Thank you for reaching out to the RUCKUS Community Forums.
Could you please confirm if this inquiry is related to a RUCKUS setup in a Lennar Home?
Looking forward to your response.
What is Lennar home?
Hi @sfdoc5
Thank you for your response.
Lennar Homes is a separate segment of RUCKUS customers, where our devices are pre-installed in their smart homes. Based on your setup, it does not appear to fall under this category.
For now, please try restarting the Access Point by turning it off and on from the power outlet, or by unplugging and reconnecting the Ethernet cable from the Switch port (if powered via PoE). After this, check if the issue is resolved.
Additionally, consider going through the Article below:
https://www.192-168-1-1-ip.co/router/ruckus-wireless/r750/24863/
Also, please note that the default IP addresses don't work; You can verify the assigned IP address of the AP using an IP scan. The following article provides guidance on performing an IP scan:
/kb/articles/10-how-to-find-the-ip-address-of-the-ruckus-devices-switch-and-aps-using-ip-scanner-free-applications
Kindly let us know the results. If the issue persists, one of our engineers from the appropriate team will assist you further.
Best regards,Imran SanadiRUCKUS | Community Forum Support
