Hi Rahul,
Thank you for reaching out with your query!
I understand that you are using a Ruckus ICX switch along with two access points (APs) to provide Wi-Fi for your smart devices, such as your Ring, garage door, lights, and switches.
You've reported that after any power outage, the switch fails to reconnect to the internet, which puts the APs and Wi-Fi devices in a cycle of connecting and disconnecting. This issue can take hours or even days to resolve, often forcing you to bypass the switch and connect directly to your modem/router for work.
You confirmed that your APs are up to date. However, you cannot access the switch firmware version, which may be outdated. Since you only have a Mac or iPad and no Windows PC, you haven't been able to use PuTTY to check or upgrade the switch.
To access the switch using your Mac, please refer to the following link:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12CP-Ruckus-Switch/m-p/46759.
If the switch is stuck in a boot loop, we can perform a software recovery. You can find the instructions here:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483.
Could you also let us know if you are affiliated with Lennar Homes?
Please keep us updated on how this goes. If the issue persists, kindly log a ticket using the following link so we can assist you further:
https://support.ruckuswireless.com/contact-us.
I hope this information is helpful. Feel free to reach out if you have any questions or concerns.
Note: If this response addresses your query, please consider marking the post as an "Accepted Solution."
Thank you!
Mayank
Hi @rahulmunjal
Based on the information provided, it appears that you are encountering intermittent internet connectivity via the RUCKUS Network.
This issue may be related to the Routing Code, which can be resolved by performing a few commands in the Command Line/CLI.
Please note, we have instructions to get the Command Line (CLI) for MAC devices as well. Please refer to the mentioned RUCKUS Lennar Knowledge Base self-help article to fix this issue.
/kb/articles/2-fixing-ruckus-icx-7150-c12p-switch-routing-code-spr-issue-using-command-line-interface-cli
Please let me know how it goes, and let me know if you are stuck at any point during the process.
Thank you for getting back quickly. I tried to connect using CLI on my mac; was able to identify the IP of my switch through Unleashed as well as the Fing app. But when I try to SSH using Super or Admin as instructed, I receive an error on terminal.
Last login: Fri Aug 22 22:50:14 on console
% ssh admin@192.168.0.24
Unable to negotiate with 192.168.0.24 port 22: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
% ssh super@192.168.0.24
What should be the next step? Please suggest.
FYI - I have also tried
ssh-keygen -R
% ssh-keygen -R 192.168.0.24
Cannot stat /Users/xxx/.ssh/known_hosts: No such file or directory
Telnet just does not show the prompt either... although no error is displayed.
% nc 192.168.0.24 23
What should be the next step I can try??
Please try to log into the RUCKUS ICX-7150-C12P Switch Dashboard in the Web Browser.
You should see the Switch Dashboard as shown in the screenshot below to confirm it’s a Switch IP Address.
Please let me know once you log in and let me know if you have any queries in this regard.
Thank you again for your patience and understanding
Thank you.
