I have purchased an ICX-7450-48P from amazon, both pri and sec flash is showing SPS080300h.binHow do I get it to reload SPR codes, where can I find the codes? Thanks
Hi Davyk,
Thank you for posting your query !!!
I understand that you would like to have spr code.
You can refer to the below link for your reference :
https://support.ruckuswireless.com/software/1233-ruckus-icx-fastiron-08-0-30-software-release-zip
However i would recommend you to got to our stable patch i.e. 8095r below is the upgrade path
8030 --->8080f(non ufi) ---8080f(ufi)--8095r(ufi)
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further.
I hope this information helps you
Please feel free to leave us a message if any concerns
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
