Hello Imran, I keep having these same issues with my Ruckus system after a power outage. Was a post ever made to show how to upgrade the switch to the latest stable version to avoid these issues moving forward?
Hi @RexH
Based on the information provided, it appears that you need assistance with upgrading your RUCKUS Switch to a recommended version.
It’s good to have the Switch on a stable version to avoid any issues.
Before I assist you with the upgrade, could you please let me know your RUCKUS ICX-7150-C12P Switch version that is currently running on?
If you don’t know the current version, please follow the process below and help us with the mentioned command outputs to check the same.
1. First, identify the current IP address assigned to the switch ICX-7150-C12P by your local router. You can use an IP scanner tool to easily locate the switch's IP address on your network. Here is a guide on how to perform this using the IP Scanner free applications:
/kb/articles/10-how-to-find-the-ip-address-of-the-ruckus-devices-switch-and-aps-using-ip-scanner-free-applications
2. Once you have identified the IP address of the switch, proceed to access the Command Line Interface (CLI) of the RUCKUS ICX-7150-C12P switch. Here is a guide on how to access the CLI:
/kb/articles/8-how-to-access-the-command-line-interface-cli-of-the-ruckus-icx-7150-c12p-switch
If you can access the Command line the prompt should look like below:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
3. After successfully accessing the CLI, please execute the following commands and provide the outputs:
show version
show flash
Please share the command outputs or screenshots if you encounter any issues or errors during these steps.
Thank you.
Best regards,Imran SanadiRUCKUS Lennar Home Community
