I am planning to enable simple RSTP on our 7550 switch which is also connected by trunk to 3rd party switch already running RSTP.
I see the way to enable it is to run command "spanning-tree single 802-1w" however I see on the list after tabbing single there is also RSTP on the bottom of options.
So what would be the difference of running "spanning-tree single 802-1w" vs "spanning-tree single RSTP"?
