ICX Switches
ICX7750 randomly rebooted. Standby took over
ICX7750 randomly rebooted. Standby took over.
Anyway to see what caused the reboot?
Also what is the recommended version to go to on this? Currently at SWR08030a and boot is at 10.1.05T205
BenBeck
You generally need to open a tac case for this. I would gather the following for support to analyze:
show tech
dm save <1-4>
supportsave all
If unit 1 is no longer active (check in show stack), you will need to rconsole to gather dm saves. It would look like this:
rconsole 1
dm save <1-4>
As for code, the 8030 stream is the most mature. I would go with 8030s.
Hope that helps!
