I have two R510's in my home, one is working perfect. The other will not respond to a factory reset, and is flashing RED on the PWR light slowly.
Does this AP need to be replaced?
Hi @ryandriven
Based on the information provided, it appears that one of your Access Points is not working.
Please unplug the ethernet cable of this Access Point the Switch port and plug it back into any other available 1-in-12 ports as highlighted in the below screenshot. Once done, please check if that comes to the normal state.
Please let me know how it goes.
That did not work. The AP is still flashing red.
Could you please try connecting the affected Access Point to an external power 12 VDC adapter and check it separately without connecting to the Switch PoE port cable? (Please refer to the below screenshot). Usually, you will find the 12 VDC adapter connected to your ISP’s (Internet Service Provider’s) Router/Modem-Router combo device.
Once connected try to perform the factory reset of the Access Point as described in the below guide.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Physical-Factory-Reset-an-Access-Points-Ruckus/td-p/47056
Please check the Access Point following the above process and let me know if you have any queries in this regard.
Hi, I reset using the 12v adapter. This did NOT work. I still have a flashing red light. Can we replace the unit?
Thank you for your response and the information provided on the private chat.
We kindly request that you connect your RUCKUS R510 Access Points (APs) one by one to a functional power outlet and share both pictures and a single video showcasing the light status, the cord connected to the APs, and its connection to a working power outlet. Please refer to the example pictures provided below for guidance.
For the video upload, we have created a designated link for your convenience. You can access it via the following link: (Refer to the EXAMPLE VIDEOS from this drive link)
If you have any questions or need further clarification, please don't hesitate to reach out.
Best regards,Imran SanadiRUCKUS Lennar Home Community.
Thank you.
Hi - I shipped back the RMA AP. Tracking shows Ruckus has received it. Can you provide an update on shipping back the replacement AP?
Tracking:1Z2618W50386031075
Thank you for your response.
Apologies for any confusion, but this process is not related to our area of support.
Please note that this forum is primarily dedicated to providing technical assistance and handling RMA approvals for defective devices for RUCKUS Lennar Home users. For information related to other processes, kindly use the same chat link.
Thank you for your understanding.
