I followed the instructions in this article RUCKUS Forums - How to perform a Software recovery on an ICX7150 s... - CommScope RUCKUS Community Forums however after installing the SPS08090k.bin image file using the Putty command line, the switch would boot up and ask for a login and none of the default logins work. The last step in the article says I need to update the image to the latest version so I want to make sure this will not cause issues. I tried unplugging power from the switch, and then restoring it, pressing "B" in Putty to start the boot monitor, but there was some error in trying to set the new updated image "SPR10010f_cd1ufi.bin". Is this the correct image file to use for the latest version?
