What is the handover rate in multi-access point location, where a client needs to connect to good signal nearby..........
anil_piske
In the architecture when all access points are controlled by Zone Director what is the handover (switch over rate ) rate  in multi-access point location, where a client needs to connect to good signal nearby...........
3 REPLIES 3
robert_lowe_722
Contributor III
Not sure I understand your question 100%. Are you asking at what signal strength a client needs to see another AP in order to roam between access points?
anil_piske
Yes because the client is connected at low signals to the same access point even when it is near another access point with good signal.
monnat_systems
Valued Contributor II
Hi Anil...
read the KBA below
https://support.ruckuswireless.com/answers/000002277
this should help...
