I have an ICX-7150-C12P that suddenly will not power on. I have tried disconnecting and reconnecting the power cable to a working power outlet, however, no lights come on the ICX-7150-C12P. Can I please get an RMA for this? Thank you.
Picture of connection to working outlet
Picture of connection to working outlet 2
Hi @David_ICX7150
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, LEDs stays off. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Based on the information provided, it appears that you are encountering issues with RUCKUS ICX-7150-C12P Switch not powering on.
If that doesn't work even with a working power cord or other power outlets, I recommend again attempting a physical factory reset multiple times, as outlined in our RUCKUS Lennar Knowledge Base self-help article accessible through this link and VIDEO:
/kb/articles/11-process-for-performing-a-physical-factory-reset-hard-reset-on-the-ruckus-icx-7150-c12p-switch
If the initial reset attempts do not resolve the issue, please try resetting your switch multiple times (approximately 10-15 times) using the method described in the article. In some cases, repeated attempts have successfully resolved similar issues. Upon successful reset, the SYST and PWR lights should turn GREEN.
Please proceed with these steps and let me know if the switch powers on successfully afterward.
Thank you for your patience and cooperation in this matter.
Imran Sanadi RUCKUS Lennar Home Community
Hello Imran,
I tried factory reset over 15 times. There are still no lights lighting up on the switch.
Thank you.
Please Confirm once uploaded.
Here is a video showing factory reset. These were the 18th and 19th attempts at a factory reset.
Video of factory reset ICX-7150-C12P, 18th and 19th attempts
Thank you for your response.
Kindly refer to the video recording guidelines outlined in my previous post and upload the recording to the drive link I provided.
Thank you once again for your cooperation and understanding.
Best regards,Imran SanadiRUCKUS Lennar Home Community
Please let me know if my videos are acceptable.
https://drive.google.com/file/d/199WQpexz76MlZwl5BfZ1hH-qPOfu3vHr/view?usp=drive_link
https://drive.google.com/file/d/1EckgyiDORPh_nL6p5w7oAjuXfI8N_SFy/view?usp=drive_link
