Hi @kenny23 ,
From the case description, I understand that the status lights on the Switch is Amber and the PWR light is Green which means that the Switch is stuck in the boot mode.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Also, I understand that you have followed the steps online and still stuck in boot
May I please know if you have performed reset on Switch multiple times and if the reset still doesn’t work, could you please mention the point where you are getting stuck during Software recovery?
If you could share screenshot, we could look into the matter and assist you accordingly.
Best regards, Pinky Rajendran
Hello @kenny23 ,
Thank you for the response and sharing the pictures.
I understand that you are unable to type anything in the Putty and getting error that the access is denied.
Please make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file, the driver should be installed using the 2 links below.
Link 1: https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Link 2: silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
Could you please restart the laptop after installing the drivers and check the COM port details in the Device Manger from the Control Panel?
COM port details should be with the silicon lab name in the device manager.
thank you. i followed your directions, ive gotten further. but stuck again, pls help attached photos not alive in ping test
We appreciate the information you've provided regarding your efforts to perform software recovery on the RUCKUS ICX-7150-C12P Switch.
AS you mentioned that you are getting a 'ping not alive' error during the software recovery process, we recommend temporarily disabling the Windows firewall.
Please refer to the below RUCKUS Lennar Knowledge Base self-help article on Fixing “host 192.168.0.x is not alive” (not alive) error during the Switch Software Recovery Process
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-host-192-168-0-x-is-n...
Please feel free to reach out if you have any further concerns or queries.
Best regards
Pinky RajendranRUCKUS Lennar Home Community
hello, i have disabled the windows firewalls and am still "not alive", on the putty ping test.,please advise on what to try next. thank you in advance
From the response you shared, I understand that you are still getting the ping not alive error message even after disabling the Windows firewall.
May I please know if you have performed the commands mentioned in the article after disabling the Windows firewall?
If yes, could you please let us know if you are getting stuck at any point.
Please share the screenshot of the error message so that we could assist you in a better way.
Hi @kenny23
Thank you.
Best regards,Pinky Rajendran
