How to trouble shoot connection
Hi @Jamesmcmillan33
Based on the information provided, it appears that you are encountering Wi-Fi internet connectivity issues at top floor via RUCKUS Access Point.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
3. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.4. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Imran Sanadi RUCKUS Lennar Home Community
To proceed further I would appreciate your help in providing the information I requested in my previous communication.
Thank you.
Best regards,Imran SanadiRuckus Lennar Home Community
you need to install a mesh network system , This system creates a unified Wi-Fi network throughout the house with several access points, ensuring homogeneous coverage on all floors.or Change the Wi-Fi channel: If the signal is disturbed, changing the Wi-Fi channel on your router can improve the signal quality.
Tutuapp
Hello @sari
Thank you for your valuable suggestion. We sincerely appreciate the time and assistance you've provided.
Please don't hesitate to contact us with any further queries or concerns regarding RUCKUS Lennar Home setups.
Once again, thank you for your time and support.
Best regards,Imran SanadiRUCKUS Lennar Home Community
