I have unplugged and plugged. Also followed the YouTube video for resetting the device. Nothing helped. It is not powering at all. No lights show up at all
Hi @kvamshi
We appreciate the information you provided regarding your RUCKUS ICX-7150-C12P Switch not powering on and that you tried to hard reset.
- The switch is plugged into a working power outlet.
I have uploaded a video . Please review
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Hi Imran,
Support has shipped the ruckus main box. I am testing the access points on the different floors. When I plugged in Ethernet wire for the access point I don't see the access point light up green. How do I troubleshoot the access point issue ?
