After power outage internet via Ruckus not working ..everything is green on Ruckus and access points..please suggest on how to fix it
Hi @kvarshne ,
From the case description, I understand that your Ruckus setup is not working after the power outage.
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is running in the Routing code.
/kb/articles/2-fixing-ruckus-icx-7150-c12p-switch-routing-code-spr-issue-using-command-line-interface-cli
Please follow the process as explained in the article and let me know if you have any queries in this regard.
Hello @kvarshne ,
Thank you.
Best regards,Pinky Rajendran
