Really wish Ruckus would look into this. I have the same thing. Random disconnects ONLY on my work VPN. Otherwise connection is solid.
Hi @david_fry_jz089
Based on the information provided, it appears that you are encountering intermittent internet connectivity.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
3. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.4. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please help me with ALL the above queries and Should you have any further questions or concerns, feel free to reach out.
Imran Sanadi RUCKUS Lennar Home Community
Thank you.
Best regards,Imran SanadiRUCKUS Lennar Home Community
