Hello. I just received the new Switch Unit replacement and confirm that the status lights are appearing on the new device. Can you please tell me how I can get it connected to my existing Access Point?
Hello @Dylannn23 ,
As per the case description, I understand that you have received the replacement Switch from Ruckus and you are looking for assistance with the setup.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
/kb/articles/12-ruckus-lennar-home-devices-connectivity-setup-and-configuration-guidelines
Should you require further assistance or have any questions, please do not hesitate to reach out.
Thank you! Since I no longer have a wifi name or password with the new Switch (step 6, Figure 7), do I need to reset my access point to factory settings?
As there is no wi-fi name or password with the new Switch, you will need to perform a factory reset o the Access points as mentioned in the article.
You may refer to the factory reset article mentioned in the step 7
