Switch is an icx 7150-c12p. at the moment no port is providing POE. I have to use an injector to have the Ruckus AP working. I have to restart the switch a lot for maybe a port or 2 to work. Things are working slow as well.
I have things connected to 9 of the ports and only 4 are showing up. Switch says POE is ok but it is not. Temperature is ok. Please see output from switch below. Please let me know what we can do to replace. This switch is broken.
telnet@ICX7150-C12 Switch# show chassis
The stack unit 1 chassis info:
Power supply 1 (AC - PoE) present, status ok
Fanless model
Slot 1 Current Temperature: 70.5 deg-C (Sensor 1), 10.0 deg-C (Sensor 2), 57.2 deg-C (Sensor 3), 52.8 deg-C (Sensor 4)
Slot 2 Current Temperature: NA
Slot 3 Current Temperature: NA
Warning level.......: 100.0 deg-C
Shutdown level......: 109.0 deg-C
Boot Prom MAC : d4c1.9e1e.783b
Management MAC: d4c1.9e1e.783b
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Down None None None None No 1 0 d4c1.9e1e.783b
1/1/2 Down None None None None No 1 0 d4c1.9e1e.783c
1/1/3 Down None None None None No 1 0 d4c1.9e1e.783d
1/1/4 Down None None None None No 1 0 d4c1.9e1e.783e
1/1/5 Down None None None None No 1 0 d4c1.9e1e.783f
1/1/6 Down None None None None No 1 0 d4c1.9e1e.7840
1/1/7 Down None None None None No 1 0 d4c1.9e1e.7841
1/1/8 Up Forward Full 1G None No 1 0 d4c1.9e1e.7842
1/1/9 Up Forward Full 1G None No 1 0 d4c1.9e1e.7843
1/1/10 Down None None None None No 1 0 d4c1.9e1e.7844
1/1/11 Up Forward Full 1G None No 1 0 d4c1.9e1e.7845
1/1/12 Up Forward Full 100M None No 1 0 d4c1.9e1e.7846
1/2/1 Down None None None None No 1 0 d4c1.9e1e.7848
1/2/2 Down None None None None No 1 0 d4c1.9e1e.7849
1/3/1 Down None None None None No 1 0 d4c1.9e1e.784a
1/3/2 Down None None None None No 1 0 d4c1.9e1e.784b
mgmt1 Down None None None None No None 0 d4c1.9e1e.783b
