I have a ICX 7150 and after a power outage the the green pwr button is illuminated and the amber System one. I tried the hard reset and it just blinks amber for an hour if I let it. Any advice?
Hi @jtabz87
Based on the information provided, it appears that you are encountering issues with RUCKUS ICX-7150-C12P Switch with Amber SYST light.
The Amber SYST and Green PWR lights indicate that the Switch is in boot mode. Since you’ve already attempted a hard reset with a paper clip, please try this reset process multiple times. If the issue persists, the next step would be to perform a software recovery on the Switch.
For detailed instructions on the troubleshooting process, please refer to the following RUCKUS Lennar Knowledge Base article:
Fixing RUCKUS Switch with an Amber/Orange Light on "SYST"
Please follow the steps outlined in the article, and let me know if you need any assistance or encounter any difficulties during the process.
Thank you once again for your patience.
Imran SanadiRUCKUS Lennar Home Community
Thank you for the response, I have been trying these steps since last night, but the amber lights all just flash and nothing happens. Any other advice?
Please proceed with the software recovery process of the RUCKUS Switch as described in the same article.
Let me know if you are stuck at any point during the process.
Sent you a message!
Hi @dhp
Since this post was created by @jtabz87 to avoid confusion, please start a new post if you need any assistance.
Thank you for your understanding.
Best regards, Imran Sanadi RUCKUS Lennar Home Community
Are there different instructions for Mac? What if I don’t have an Ethernet port to do the factory reset?
For the software recovery process, I recommend using a Windows laptop or PC, as it may simplify the procedure.
Please let me know if you can proceed with this.
Thank you.
Best regards,Imran SanadiRUCKUS Lennar Home Community
