We had a power outage two weeks ago. First both our R510 didn’t power back up after the power went back on. We performed a power cycle of the ATT main router and the main Ruckus router. The power for both AP then finally turned back on. We get internet from the APs but it is unreliable. Sometimes even our main wifi breaks connectivity on its own. Our wifi performance overall have been degraded. I also cannot connect to the unleash application nor can I log in on the default IP for both Ruckus AP. When I log in to my ATT router, I see the list of equipment that uses/used our WiFi and Ruckus Unleash show “off”. I’ve read that firmware update for the AP should fix this, but I would need to log in to the default IP for the AP which I cannot do. Some suggest that I should try factory resetting. Will this really fix my problem? Is there a specific version of the Ruckus Unleash iOS app that I will also require? Please advice.
