ZoneDirector
How to upgrade Zonelfex 7962 Firmware without a Zone Director on network?
I am using the Zoneflex 7962 in standalone mode (an an AP connected to a wired router). I want to upgrade the firmware and any software for it. Is there a recommended procedure if there s no Zone Director on the network?
I would prefer not to use a server via the Internet and also would rather not go through setting up a dedicated server on the LAN. This is for SMB use and it is a peer to peer network.
Hi Dee Bee,
You can try the upgrading via option - Upgrading Manually via Local File. this would suit you the most.
refer to PDF page no 111 on
https://support.ruckuswireless.com/do...
hope this helps.
