Hi, I have the Ruckus system ICX 7150-C12P. I can't power it on or reboot after the electric outage. Please let me how to fix it. Thanks.
You need to insert a console cable to query its console output information.
System issues can be upgraded under boot.
硬件故障可以通过 RMA 处理!
谢谢
Hi @PQ ,
As per the case description, I understand that your RUCKUS setup is not working, and Switch do not have power.
I would request you to please perform a hard reset on the Switch and confirm if there are any lights flashing.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to hard reset the Switch
/kb/articles/11-process-for-performing-a-physical-factory-reset-hard-reset-on-the-ruckus-icx-7150-c12p-switch
Please follow the process as explained in the article and let me know if you have any queries in this regard.
HI, Rajendran,
Thanks for the reply. I have tried unplug and plug the power cable, try to reboot but they system never completed the rebooting process. Only the power light is green, the system light is orange. What should I do next? Thanks.
PQ
Hello @PQ ,
From the response shared, I understand that the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Thanks for the followup. I was not able to successfully reboot the system by trying several times. I may have to try over 15 times to see if that works. But can you send me the mac version of how to recover the software. Thanks.
