Does anyone know where to purchase a replacement power supply for ICX 7150-C12P?
Thanks,
Hi @noypi-cker
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Apologies, In order to provide you with the most effective assistance, could you please provide further details regarding the issue you are experiencing?
Hi Imran,
When I plug the switch the LED on the front will lit for 1 second then nothing after that. Is it a bad power supply?
Hello @noypi-cker
Thank you for providing the information.
Based on the details you've shared, it appears that your RUCKUS ICX-7150-C12P Switch is not operational.
Could you please let me know if you tried to power it up using a different working power cord with different working power outlets? If no, please try it once.
If that doesn't work even with a working power cord, I recommend attempting a physical factory reset multiple times, as outlined in our RUCKUS Lennar Knowledge Base self-help article accessible through this link and VIDEO:
/kb/articles/11-process-for-performing-a-physical-factory-reset-hard-reset-on-the-ruckus-icx-7150-c12p-switch
If the initial reset attempts do not resolve the issue, please try resetting your switch multiple times (approximately 10-15 times) using the method described in the article. In some cases, repeated attempts have successfully resolved similar issues. Upon successful reset, the SYST and PWR lights should turn GREEN.
Please proceed with these steps and let me know if the switch powers on successfully afterward.
Thank you for your patience and cooperation in this matter.
Imran Sanadi RUCKUS Lennar Home Community
Yes I have tried it with two working power cord. Ok i'll try to reset it later when I get home. Thank you.
