Ruckus WiFi networks haven’t been working for months so I’ve just been using my WiFi from my ISP router instead. WAPs all have green lights. I can see my Ruckus networks on all my devices. They just don’t work. Please help!
Hello there🙂
Try these steps if your Ruckus WiFi networks are displayed but not working. I hope this will helpful for you🤗
Hi @ryanchapman
Based on the information provided, it appears that you are encountering internet connectivity issues via RUCKUS.
1. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?2. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
3. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.4. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please upload these photos to your RUCKUS account before proceeding.
Imran Sanadi RUCKUS Lennar Home Community
Thank you.
Best regards,Imran SanadiRUCKUS Lennar Home Community
I kindly request an update on my previous private chat.
