7762 PoE power usage
Whats the real world power usage of a 7762 (Not S) with the PoE disabled?
keith_redfield
Do you mean the POE out disabled?
I'm trying to understand the power budget I need on my switch for each AP. Was just suggesting I don't need the PoE out enabled.
keith_redfield
OK, that makes it easier since switches often report on the actual power draw (but not if POE to the AP is disabled
Has anyone got a reading?
