ZF7055 providing downstream PoE and dual SSID wi-fi to 2nd AP - model specific control
I have a zf7055 providing downstream PoE and dual SSID wi-fi to a zf7363 using VLANs to segregate the guest wi-fi from the private wi-fi. We also use a ZD1106. I just came across the "model specific control" to configure the ports on the zf7055. The issue I'm experiencing is the zf7363 only connects successfully to the private wi-fi and the guest wi-fi pulls an APIPA IP. Is there an example on how to set the model specific control for LAN4+PoE port for this configuration so the guest VLAN also passes to the zf7363?
Comments
There are no comments yet
