I just noticed that our wireless extenders are no longer working. I tried doing a factory reset but it did not work. Can you please provide further assistance? I am not great with technology. Thanks!
Hi @kristenrwillis ,
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
1. Was there any power outage before you started facing this issue?
Hello, I have the same issue after a power outage. I have tried resetting the system, but your directions aren't clear on how long I should keep the paper clip in after I put the power chord in. I see the amber lights come on immediately after I plug the chord in with or without the paper clip on. Please explain.
Hello @Edrisgarcia4182 ,
Thank you for your response to the post.
I understand that you are experiencing issues with the Switch following the power outage. Could you please create a new post on the Community forum since this case involves a different user? Once you have created the new post, we will be happy to assist you further.
Please use the below link to create a new post in the Community forum.
https://community.ruckuswireless.com/t5/forums/postpage/choose-node/true/interaction-style/forum/override-styles/true
Hello @kristenrwillis ,
