I have a client with a dead zone director. Its a residential facility. 64 AP's total. I was going to do a separate instance for each floor. My question is the current setup has every AP on its own vlan and ssid. How do I accomplish that with the unleashed solution? I have the correct firmware, but when I try to use remote management it won't join.
My understanding is I need to create an AP group for each vlan/ssid, but is there a group member limit? Or a number of groups limit?
