My father-in-law has a Ruckus ICX7150-C12P that was part of his new Lennar build in 2019. He has 3 R510 WAPS and a Ring Elite Doorbell – all operating by POE from the Ruckus. For over a year, there has been no POE functionality. The WAPS and the doorbell are unable to function due to their inability to receive POE from the Ruckus. We believe the POE stopped working after a power outage at the home.
This past week, I started to do some troubleshooting, in an effort to resolve his problem with the Ruckus, and I came across this community. I’ll telnetted into the Ruckus and printed out screens that appear relevant, based upon reading through the community. I thought I had the Lennar boot to Router vs Switch, but that theory was dismissed after learning the system was booted in the “switch” partition all along (see screenshots below). I tried to power the system down; used the reset button; unplugged and replugged cables; etc. The System and Power lights are green;
I cannot figure out why the system no longer is providing POE. I did run power over the ethernet cable to each device and confirmed the devices were each receiving power, just not from the Ruckus. I am now lost. I am starting to think the unit is just broken. Any help is greatly appreciated.
Here are excerpts from CLI Session
telnet@ICX7150-C12 Switch>show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserv ed.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary SPS08061a.bin
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110 ) Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3236N06K
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 47 second(s)
--More--, next page: Space, next line: Return key, quit: Control-c^C
telnet@ICX7150-C12 Switch>enable
telnet@ICX7150-C12 Switch#conf t
telnet@ICX7150-C12 Switch(config)#
telnet@ICX7150-C12 Switch(config)#no logging console
telnet@ICX7150-C12 Switch(config)#enable
telnet@ICX7150-C12 Switch#show version
1024 MB DRAM
STACKID 1 system uptime is 9 minute(s) 15 second(s)
The system started at 00:02:02 GMT+00 Sat Jan 01 2000
telnet@ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 24723488, Version:08.0.61aT211 (SPS08061a.bin)
Compressed Sec Code size = 24723488, Version:08.0.61aT211 (SPS08061a.bin)
Code Flash Free Space = 1311514624
telnet@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 31600 mWatts.
Power Allocations: Requests Honored 6 times
1/1/1 On Off 0 15400 n/a n/a 3 n/a
1/1/2 On Off 0 15400 n/a n/a 3 n/a
1/1/3 On Off 0 15400 n/a n/a 3 n/a
1/1/4 On Off 0 15400 n/a n/a 3 n/a
1/1/5 On Off 0 15400 n/a n/a 3 n/a
1/1/6 On Off 0 15400 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 0 92400
telnet@ICX7150-C12 Switch#show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Down None None None None No 1 0 78a6.e12e.cef0
1/1/2 Down None None None None No 1 0 78a6.e12e.cef1
1/1/3 Down None None None None No 1 0 78a6.e12e.cef2
1/1/4 Down None None None None No 1 0 78a6.e12e.cef3
1/1/5 Down None None None None No 1 0 78a6.e12e.cef4
1/1/6 Down None None None None No 1 0 78a6.e12e.cef5
1/1/7 Down None None None None No 1 0 78a6.e12e.cef6
1/1/8 Down None None None None No 1 0 78a6.e12e.cef7
1/1/9 Down None None None None No 1 0 78a6.e12e.cef8
1/1/10 Up Forward Full 1G None No 1 0 78a6.e12e.cef9
1/1/11 Up Forward Full 1G None No 1 0 78a6.e12e.cefa
1/1/12 Up Forward Full 100M None No 1 0 78a6.e12e.cefb
1/2/1 Down None None None None No 1 0 78a6.e12e.cefd
1/2/2 Down None None None None No 1 0 78a6.e12e.cefe
1/3/1 Down None None None None No 1 0 78a6.e12e.ceff
1/3/2 Down None None None None No 1 0 78a6.e12e.cf00
mgmt1 Down None None None None No None 0 78a6.e12e.cef0
Total 0 92400
telnet@ICX7150-C12 Switch#enable
Incomplete command.
telnet@ICX7150-C12 Switch#configure terminal
telnet@ICX7150-C12 Switch(config)#interface ethernet 1/1/7 to 1/1/12
telnet@ICX7150-C12 Switch(config-mif-1/1/7-1/1/12)#inline power
telnet@ICX7150-C12 Switch(config-mif-1/1/7-1/1/12)#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 1600 mWatts.
Power Allocations: Requests Honored 7 times
1/1/7 On Off 0 30000 n/a n/a 3 n/a
1/1/8 On Denied 0 0 n/a n/a 3 n/a
1/1/9 On Denied 0 0 n/a n/a 3 n/a
1/1/10 On Non-PD 0 0 n/a n/a 3 n/a
1/1/11 On Non-PD 0 0 n/a n/a 3 n/a
1/1/12 On Non-PD 0 0 n/a n/a 3 n/a
Total 0 122400
