Have one production building and one under construction, not temperature controlled, with storage yard in between. A dozen employees. Total rectangular footprint is approx. 400' x 150'. WiFi currently is limited to the offices immediately around the wiring closet in one building. We need better WiFi mostly for mobile calls on the entire footprint as cell service is not ideal; and need mesh for continuity between buildings. No portable apps in use currently. I'm thinking we deploy one Ruckus T350 in the center of each 22-ft ceiling building, and one on the outside of one building to provide the best yard coverage, all POE.
Is it that simple? Can I buy 3 T350s and support? Is there a better way to deploy? They seem to be hard to locate from generic sources. Thanks from a noob.
