My switch is showing solid amber light for system and solid green for power.
My Access points are not receiving power.Ā Ā
Please assist.
Thank you š
Ā
Hello @manny_ajvalia ,
From the case description, I understand thatĀ the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
/kb/articles/4-fixing-ruckus-switch-with-an-amber-orange-light-on-syst-green-light-on-pwr-no-lights-on-aps
Please follow the process as explained in the article and let me know if you have any queries in this regard.Ā
Hello:
The video was very informative.Ā However can you show/explain how and where to connect the USB-C and Network cables on the switch?
Thanks.
From the response, I understand that you need assistance in connecting the ethernet cable and the C-type cable.
Please refer to the below picture to understand the connection between the cables.
A console cable connected between your Computer to the ICX 7150 Switch Type-C USB console port.
Note:Ā The cable type will be USB to type C, where the USB itās going to your computer and the type C to the Type C connection in your switch, is the port number#1 in the next guide.
Port-side view
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-98DBADCF-277F-4450-8A0B-58A4F916179...
Ā Ethernet cable connected between the Out-of-band management port in the Switch to your computer Ethernet port.
Please use this video link for reference:
Please note, we must useĀ ethernet cable (both ends RJ45 plugs) and USB to type C cable both togetherĀ as described in steps 2 & 3 in the guide link.
Thank you for the detailed explanation.
QUESTIONS: for my switch:Ā Ā ICX 7150-C12P,Ā 1. what is the "4.Ā Slot 1 (10/100/1000 Mbps RJ-45 downlink) ports" used for?2. what is the "Slot 2 (10/100/1000 Mbps RJ-45 uplink) ports (half-duplex is not supported on these ports)" used for?3. what is the "Slot 3 (SFP+ uplink or stacking ports)"4. Which ports should I connect my 2 two APs in?
Thank you.
