What is the link that you used to return?
Hello @Shoats
Warm greetings from RUCKUS Lennar Home Community.
Thank you for reaching out to us. I trust you're doing well.
To assist you effectively, could you please provide a detailed explanation of the issue you're encountering with the RUCKUS devices? Any specific symptoms, error messages, or observations you've noted would be helpful for us to proceed with troubleshooting.
Once we have a clearer understanding of the problem, we'll be able to provide you with appropriate guidance and support.
Thank you for your cooperation and understanding.
my Roku switch has no power. I tried to reset it multiple times I even took the plug out and plug it back in and all it does is the amber lights flash and that’s it. And no other lights are on even my access points have no lights. Will I be able to return this for a new one?
Hi @Shoats
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering up and you tried to reset it multiple times.
Please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet. Please refer to the below pictures as an example.
Please use the below link to upload a VIDEO: (Refer to the EXAMPLE VIDEOS from the guide)
https://drive.google.com/file/d/16I6IZWABp5magqaReoVEEF4KrW-4ryKT/view?usp=drivesdk
http://community.ruckuswireless.com/15/RUCKUS-Support-for-Lennar-Homes/1CX-7150-C12P-takes-multiple-attempts-to-boot/m-p/50214
Thank you for your response.
Kindly proceed with the instructions provided in my previous message and initiate the RMA (Return Merchandise Authorization) process using the CHAT Link.
Your understanding and cooperation are greatly appreciated.
