Dear Support Team,
I use 2 T750 in the same Network. I need to build a Mesh. Is this possible without a zone controller?
If yes, what settings should I use?
With kind regards,
DLR-Fred
Install Unleashed on your T750s.
Tick the Mesh checkbox in the setup wizard if one of the APs will be using wireless backhaul.
