My Ruckus switch ICX 7150-C12P stopped working. The switch is powered but no led is ON. When I power ON the module, I see all the leds blink amber for a second and then all leds go back to off. I tried to reset to factory default multiple times (using the reset pin hole), and I still have the same result. I also tried to communicate with the switch via Putty/serial connection and the device is not communicating. Any idea how to fix it?
