Ruckus ZoneFlex R510 AP receiving no power. The POE is not working. Tried plugging in a 12 volt and still no power.
Hi @Ruckus2
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let me know the answer to the above query and let me know if you have any queries in this regard.
Thanks for your reply. Here are the photos. No lights and tried to push reset button with no change.
Please unplug the PoE ethernet cable of this AP from the Switch port and plug it into any other 1 in-12 ports (please refer to the screenshot below) and check if that powers up.
If that doesn’t work, please plug your Access Point into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and 12 VDC power adapter connected to the AP, and a working power outlet. Please refer to the below pictures as an example.
Please refer to the EXAMPLE VIDEO (Use AP in place of Switch from Ex Video) and use the below link to upload a VIDEO:
Okay, the video is uploaded.
thank u for ur information
