My APs don't power up and ring bell and thermostats don't have internet access. Tried resetting the Ruckus device hundreds of times but failed.
I wonder there this needs the whole system replaced.
Thank you!
Hi @NP
Apologies for the inconvenience caused.
As per the case description, I understand that your RUCKUS setup is not working and Access Points have no power.
Please let us know the answers to the below queries to assist you better.
1. If it worked before, was there any power outage before you started facing this issue?
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
I kindly request an update on the status of the issue so that we may proceed further with resolving it. Please help us with the requested queries.
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
Best regards,Imran SanadiRUCKUS Lennar Home Community
1. There could be a power outage but I don’t know definitely. It was not working when I got back from work.
2. No light is on, pictures attached earlier.
The 3 devices sitting on the device have lights on but ICX and AP don’t..
Thank you for the response and the details.
As described in my initial post, please share a picture of the RUCKUS ICX-7150-C12P Switch showing the light status and cable connections.
Please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and a VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet. Please refer to the below pictures as an example.
Please use the below link to upload a VIDEO: (Refer to the EXAMPLE Videos from the drive)
Please see the device connected to a working outlet (no light at device input and no light on the status indicating led light on the device. The Ruckus device is dead.
Thank you for your response.
I kindly request you to refer to my previous communication and proceed with uploading the pictures and a video onto the drive, showcasing the switch connected to the functional power outlet.
For reference, please consult the EXAMPLE videos available from the provided drive link and ensure that the recorded video of your switch follows a similar format.
Once again, I appreciate your cooperation and understanding.
Your link to Google drive doesn’t let me upload the video. But as you see in the pictures, the Ruckus
device is connected to working outlet but it doesn’t power up (led indicating power status is dark) and the device is dead.
Video was uploaded to google drive many days ago. I can’t disconnect the device from wall and connect somewhere else as it has so many connections and I don’t want to mesh up but the device is/was connected to a working outlet as displayed by light. Also you can see in the pictures.I’ve tried in other working outlets in multioutlet power strip next to the device. The Ruckus device is dead as evident from pictures and video. Not sure why you are insisting to upload video and pictures again and again.
