PoE is not working from ICX 7150-c12p to R510 access point. What do I need to do?
Hi @Gaberod0007
As per the case description, I understand that the PoE from the RUCKUS ICX-7150-C12P Switch is not working,
Please let us know the answers to the below queries to assist you better.
1. If it worked before, was there any power outage before you started facing this issue?
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
Greetings! I trust this message finds you well.
I kindly request an update on the status of the issue so that we may proceed further with resolving it. Please help me with the requested information.
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
Best regards,Imran SanadiRUCKUS Lennar Home Community
I am writing to request an update on the status of the issue. Your prompt response would be greatly appreciated to proceed further.
Thank you.
