We lost power over a month ago and our AP has not worked since. We have reset it 50+ times. We also tried to recover the system 3 times. We get the error ping failed not alive. What else can we do?
Hi @evantrip08
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is stuck in the boot mode. This means that, on the Switch, there will be an Orange/Amber light on SYST and a Green light on PWR.
You tried to reset the Switch with a paper clip multiple times and tried a software recovery of the Switch with a ping not alive error.
As you are getting this ‘ping not alive’ error, please refer to the below RUCKUS Lennar Knowledge Base self-help article to fix this error and repeat the software recovery process once again.
/kb/articles/5-fixing-host-192-168-0-x-is-not-alive-not-alive-error-during-the-switch-software-recovery-process
Please follow the above process and let me know if you need any help during the process.
Hi @evantrip08 Greetings!!!
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
Yes it is.
Thank you so much! This worked!!!
