I had a power outage. My access points do not have any lights and my internet is down. How do fix this issue?
Hi @DB ,
As per the case description, I understand that your RUCKUS Access points are not powering on.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Hello @DB ,
