I tried following directions from other post however, Ruckus does not come up as a device when I'm do the iP scan.
Hi @ebalele
Apologies for the inconvenience.
As per the case description, I understand that your RUCKUS setup is not working.
Please let us know the answers to the below queries to assist you better?
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
I figured it out already. Thanks!
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
