i have problems with my ruckus t300 zone flex
during the configuration i have change de managment vlan id so i can't take control of my ap with the web browser. i would like to know if i can hard reset my ap or another solution please. i dont have have any controllers just ruckus t300 ap
martin_martin
Hi Paul,
If you look close into the RJ45 connector you can see a small reset button, press it for some time and the AP will be factory reset.
Kind regards
Martin
If you remember the Management VLAN ID you changed on the AP, you can try configuring the switch with same VLAN ID on 2 ports and connect AP and you laptop to those ports and try accessing the AP.
