After power outage, my Ruckus wireless routers have no power on and no lights. I used a different outlets, and reset them but they are still not on. Can you please help to fix them? Thank you
Hi @vantran
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
As per the case description, I understand that your RUCKUS is not powering up.
Could you please let me know the answer to the below query to assist you better?
Please let me know the answer to the above query or let me know if you have any queries in this regard.
Hi Imran,
Yes, I do see the lights on the switch. Please see attached picture.
But there are no lights on for both 2 routers:
Thank you for your help.
Could you please unplug and plug the ethernet cable of the Access Point into any other 1 in-12 ports and check? Please refer to the below screenshot. Reboot (unplug and plug from the power outlet) the Switch once.
Also, I see an ethernet cable plugged into another port on the Switch, all the device cables must be plugged into 1 in 12 ports. Please refer to the below screenshot.
I have done all as you instructed but they aren't still working. What else should I try?
Thank you
