hi, as mentioned I have two ruckus zoneflex r510 APs, after carrying out a hardware reset the AP takes the default IP 192.168.0.1 but trying to log in I can't because the user and password are not the default ones (super and sp- admin). Is it possible to access the configuration from the customer web with a master password? Or is there any other solution to the problem? Thank you
